Ability to filter using both AND + OR
  • April 20, 2020
  • 37 views
Is there any way to do this? I haven’t found a way so far. If not, I’d like to suggest this as a future feature.
  • April 20, 2020
Although you cannot use both AND and OR directly in a filter, there is a workaround using formula fields.
