Airtable draining battery
  • May 13, 2017 7:21 PM UTC
  • 40 views
I recently installed airtable on a Samsung galaxy s4 and created a simple table with just a few records of data.
Right after that the phone battery drained very quick, it lasted less then 50% of the normal time.
After I uninstalled airtable, with no other change to the phone, the battery use was back to normal.
Did anyone experience this? I can’t find any settings in airtable to limit background activities. But I don’t think there even should be, or?
  • Jul 11, 2022 4:34 PM UTC
Hi
I have an equal issue: on windows 10 using the windows app airtable is causing a very high background load after I have closed it. The only solution is to kick out the airtable leftover with the task manager.
I’m wondering what it is doing. Strange!
Help or statement appreciated!
Henri
