Base over limit - deleting records not bringing base under the limit! Help please
  • Oct 8, 2019 12:57 PM UTC
  • 198 views
Hi all - has anyone been able to bring a base back UNDER limit after going over? I’ve deleted over 10k records and emptied the trash without luck.
So basically - we hit 50k records… got the “over limit” message. I went in and cleaned up some stuff - still “over limit”.
Best answer by Partner_Marketi
Heads up anyone with this same problem - took an hour or so but the base is now back under limit after deleting the records.
Forum|alt.badge.img+20
  • Oct 8, 2019 1:46 PM UTC
Hi @Partner_Marketing
You will have to contact Airtable Support and they will return your database back to its original status, with no overlimit showing
Hope this helps.
Mary Kay
Forum|alt.badge.img+13
  • Nov 20, 2024 5:48 PM UTC
Hope this helps.
Mary Kay
is it really required to delete the trash as well?
