Changing help text based on input in a form?
  • Apr 19, 2024 4:15 PM UTC
  • 53 views
Hi! I'm trying to make it easier to check which cell phone carrier a person uses based on their phone number. Right now I have a formula I use, but formulas can't appear in forms
This is the formula I use:
IF({Phone Number} = BLANK(), '', CONCATENATE('http://www.carrierlookup.com/index.php/api/lookup?key=', {API Key}, '&number=', (SUBSTITUTE(SUBSTITUTE(SUBSTITUTE({Phone Number}, '(', ''), ') ', ''),"-",""))))
Is it possible to replicate this effect in any way in a form?
  • Apr 19, 2024 4:29 PM UTC
Fillout's advanced forms for Airtable allows formulas in forms.
