Connecting Airtable to Power BI
  • Feb 8, 2024 5:27 AM UTC
  • 319 views
Based on an earlier post on connecting airtable data to Power BI, some folks, including me, have problems reading Airtable fields/columns that have blank/missing values for some records. Based on an note from a user in the early post, I am able to revise the Airtable M Query code from the Airtable support site (https://support.airtable.com/docs/visualizing-airtable-records-in-microsoft-power-bi-power-query). I added the "List_fields"= line near the end of the query. Now the new M Query can read in all columns / fields of an Airtable table even if they have blank/missing values.
Here is the revised M Query. Hope this can be of help to you.
let Pagination = List.Skip( List.Generate( () => [Page_Key = "init", Counter=0], // Start Value each [Page_Key] <> null, // Condition under which the next execution will happen each [ Page_Key = try if [Counter]<1 then "" else [WebCall][Value][offset] otherwise null, // determine the LastKey for the next execution WebCall = try if [Counter]<1 then Json.Document(Web.Contents("https://api.airtable.com",[RelativePath="v0/"&BASE_ID&"/"&TABLE_ID,Headers=[Authorization="Bearer "&PERSONAL_ACCESS_TOKEN]])) else Json.Document(Web.Contents("https://api.airtable.com",[RelativePath="v0/"&BASE_ID&"/"&TABLE_ID&"?offset="&[WebCall][Value][offset], Headers=[Authorization="Bearer "&PERSONAL_ACCESS_TOKEN]])),// retrieve results per call Counter = [Counter]+1// internal counter ], each [WebCall] ),1), #"Converted to Table" = Table.FromList( Pagination, Splitter.SplitByNothing(), null, null, ExtraValues.Error), #"Expanded Column1" = Table.ExpandRecordColumn( #"Converted to Table", "Column1", {"Value"}, {"Column1.Value"}), #"Expanded Column1.Value" = Table.ExpandRecordColumn( #"Expanded Column1", "Column1.Value", {"records"}, {"Column1.Value.records"}), #"Expanded Column1.Value.records" = Table.ExpandListColumn( #"Expanded Column1.Value", "Column1.Value.records"), #"Expanded Column1.Value.records1" = Table.ExpandRecordColumn( #"Expanded Column1.Value.records", "Column1.Value.records", {"id", "fields", "createdTime"}, {"Column1.Value.records.id", "Column1.Value.records.fields", "Column1.Value.records.createdTime"}), #"Renamed Columns" = Table.RenameColumns( #"Expanded Column1.Value.records1",{{"Column1.Value.records.id", "_airtableRecordId"}, {"Column1.Value.records.createdTime", "_airtableRecordCreatedAt"}, {"Column1.Value.records.fields", "_airtableRecordFields"}}), #"Reordered Columns" = Table.ReorderColumns( #"Renamed Columns", {"_airtableRecordId", "_airtableRecordCreatedAt", "_airtableRecordFields"}), List_Fields = Table.ToList(Table.SelectColumns(Table.Distinct(Table.ExpandListColumn(Table.AddColumn(#"Reordered Columns", "Custom", each Record.FieldNames([_airtableRecordFields])), "Custom"), {"Custom"}),{"Custom"})), #"Expanded Record Fields" = Table.ExpandRecordColumn( #"Reordered Columns", "_airtableRecordFields", List_Fields) in #"Expanded Record Fields"
Forum|alt.badge.img+9
  • Oct 10, 2024 8:20 PM UTC
For Authentication, it is recommended to use "Anonymous" which doesn't work for me no matter what
My Date Source Settings on current file as well as Global are all set to Anonymous
  • Dec 2, 2024 4:16 PM UTC
Fantastic! Worked like a charm!
Now if there only was a way to get the values from linked records as well, then the AT PBI import would be even more useful
