Cross-Base Lookup Function & Linking Cells Between Sheets in Airtable
  • Mar 28, 2025 6:05 PM UTC
  • 103 views
I am working with two separate bases in Airtable and would like to use a Lookup field to retrieve data from a table in another base. Is there a native way to achieve this without relying on third-party integrations?
Additionally, I need to link a specific cell from one table in a base to another table in a different base. Is there a built-in Airtable feature that allows this?
I would appreciate any insights or best practices from those who have worked with similar requirements.
You can sync the table that you are looking up from to the other base using the built in sync feature.
Hey ​@Ebenezar!
You will want to take a look at this support article from Airtable. Their documentation is not always great, but they did a great job with this one.
