Formula help: Conditional IF formula?
  • December 2, 2019
  • 14 views
Hi all! I’m not sure if this can be done, but I’d like to have a column with a conditional formula.
My columns are:
Date purchased - DATE
Acquired - SINGLE SELECT (presale, second hand, trade)
Arrived - SINGLE SELECT (Y) if no I leave it blank
I have IF(Acquired=“Presale”, DATETIME_DIFF(TODAY(), {Date purchased}, ‘days’) but I was wondering if I could add that if it has arrived to either leave it blank or have 0.
I’m trying to keep track of how long it’s been since I paid for a presale and once the item has arrived the number of days is no longer required, which means a number in the column (aside from 0) would confuse me.
Is this possible?
The following should do it for you:
I hope this helps,
Julian
