Formula Help - Copy "Barcode" field into "Lookup" field
  • January 28, 2020
  • 18 views
I want to copy the results from a Barcode scan into the Lookup field so I can use a phone to scan inventory on location for a photoshoot.
I have the Lookup field working, just no luck in trying to automate the barcode info into the lookup.
I can manually copy/paste the number into the lookup field, but trying to make this workable from mobile without too much back and forth.
Thanks,
Matt
