Formula Help - Project Completed On-Time, or Late [Solved]
  • June 21, 2018
  • 29 views
Hi There,
I’m trying to create a formula for a column that will populate the text, “Complete - On-time” if the entry in the ‘Completion Date’ field is equal to or sooner than the ‘Due Date’ field. The formula will also populate the text, “Complete - Late” if the ‘Completion Date’ Field is later than the ‘Due Date’ Field.
Does anyone know what this formula would look like? Thanks in advance.
Nevermind, figured it out!
IF({Completion Date}>={Due Date},“Completed - On Time”, “Completed - Late”)
