Help with automation
  • Sep 10, 2024 6:03 AM UTC
  • 39 views
Forum|alt.badge.img+10
I need some help with an automation.
When a particular record in table A is updated, then in
Table B the contents of (Planned Move-in and Planned Move-out) in the fields (Move-in and Move-out)
What issues are you facing specifically?  It sounds like you want to find a record in Table B and update it, if so, check out Airtable's guide on how to do that: https://support.airtable.com/docs/linking-existing-records-using-automations
