Help with counter
  • Jan 4, 2023 5:02 PM UTC
  • 57 views
Forum|alt.badge.img+9
Is there a way to show a counter when as new form is submitted?
So I am with a small UK charity and we are looking at setting up a new area but to do so we need 5 founding members and 100 people to say yes I am interested (see founding members and members counters on page below)
https://www.littlemiraclescharity.org.uk/our-branches/areas-coming-soon/st-ives-huntingdonshire
Is there a way to automatically update this?  Our website is on a custom CMS so its not something I can do on wordpress I have a beautiful counter using the summary extension is there a way to have this as an iframe in order to update automatically? / Any other work around which I have not thought of - we are only a tiny charity so it really needs to be free though 😞
Any help would be amazing thanks in advance
The easiest way would be to create a view that shows the data you want and use the iframe embed like you mentioned I reckon
  • Jan 9, 2023 9:29 AM UTC
Thanks I have a view showing the data but any idea what section I could turn into an iframe?  I have used the count as an extension but I cannot make that into an iframe that I can see?
Ah I was just thinking about using a view as that comes with the embed option
I don't think you can use the dashboard with extensions as an iframe I'm afraid
