Help With Integration
  • December 19, 2018
  • 57 views
Forum|alt.badge.img+20
Hi
I want to create a scenario in Integromat to gather data from a website and place it into Google Sheets and then into an Airtable database or another Google Sheet to alert me by gmail.
Now my question is:
The website that I want to gather information from does not have API protocol, so I was wondering if a script can be written for a Mac computer and if so, can someone write one for me?
It’s a TV guide website.
I would like to have current, updated information, gathered every week for about 25 British TV Shows. The Favourites option does not give me current, updated information.
This is the website:
This is an example of a British TV Show on the zap2it website, that I would like to gather data from:
It’s the episode “VOID”, that has “NEW”, in the description.
I would like to be alerted when a “NEW” British TV show will air, there are about 25 TV Shows.
I should also mention that this website does not have API protocol, unfortunately, so I cannot use the normal Integromat modules for this situation.
Any help would be be appreciated.
Thank you,
Mary
  • December 19, 2018
Hi Mary,
Technically with Integromat you would not need an API for this type of data. You could simply use an HTTPS module with a GET or REST command I believe, along with the data set you want it to look for.
  • December 19, 2018
Hi Mary,
Hi Patrick_Ford1
Thank you for your reply.
Yes, normally that would work, but unfortunately, that’s not the case in this particular situation.
Thank you,
Mary
