How Are You Using Airtable for Property Maintenance and Repair Requests?
  • June 8, 2026
  • 90 views
danialcarter
I'm curious how others are using Airtable to manage property maintenance and repair requests.
For businesses that handle maintenance work, keeping track of service requests, technician assignments, job status, invoices, and customer communication can quickly become difficult without a structured system.
I've been exploring whether Airtable can be used to create a centralized workflow that tracks:
  • Incoming maintenance requests
  • Priority levels (urgent, standard, scheduled)
  • Technician assignments
  • Job progress updates
  • Customer contact information
  • Invoices and payment status
For example, businesses that provide services such as emergency plumbing Baltimore often need to respond quickly while keeping records organized and accessible.
Has anyone built an Airtable solution for property maintenance, facility management, or repair-request tracking? I'd be interested to hear what tables, automations, or interfaces have worked best for you.
Yeah Airtable would work fine for all of that!
re: Incoming requests, priority and technician assignments
You could have an Airtable form embedded on your website so that customers can submit requests, and have automations that’ll then auto assign them to employees and send out SMSes or emails etc to the relevant people
re: Job Progress
You’d probably do this via forms as well to keep costs low; you’d create an Interface filtered to only show the records of the logged in user and give all your technicians access.  Once a technician is assigned to a job when they sign in they’d only see their jobs, and they’d then be able to submit a form to update their job progress.  Using a normal Airtable would work well here so that each record would work as a status report in a way, but if you don’t need that you could look into using Fillout instead as that’s cleaner and lets users edit records via form submissions instead
re: Invoices and Payment
Depends on what you’re using, really.  You can set up automations to automatically send out QuickBooks Invoices or Stripe payment links etc, and then you could also create automations to update Airtable when the payments bet matched on QBO or when payment's made on Stripe, etc
All doable!
