How to create IF formula using CHECKBOX
  • July 31, 2019
  • 59 views
Hi, I want to generate a formula or to copy a field IF the CHECBOX is marked with a check. Can I do that?
JonathanBowen
Hi @Angel_Ortiz - do you mean something like this?
Formula is:
IF({Checkbox}, {Some field})
JB
  • July 31, 2019
Hello Jonathan, yes. Kind of… If I have in Field 1 (a total amount) and if the checkbox is marked, then I would like to copy what is on Field 1 or execute a formula
  • July 31, 2019
Yes!! it worked! Thanks a lot.
AO
