I have a survey that linked to contacts on a CRM I am building. Need help massively on some fields pleaseee :)
  • Aug 20, 2021 2:35 PM UTC
  • 74 views
If a person is ON the CRM but their ‘Current Title’ field is empty in the CRM. When they select their name on a dropdown list on the survey, how can I show the current title and company fields ONLY to them and not show to those that have their current title completed on the CRM?
Databaser
Forum|alt.badge.img+25
  • Aug 20, 2021 3:39 PM UTC
Hi @Maryam_Mazraei and welcome to the community!
Simple answer: you can’t. You could make a personal URL for each person that prefills their curent title/company in the form or you could use a third party app, like Stacker or MiniExtensions.
  • Aug 23, 2021 12:53 PM UTC
Oh no way! Thanks for letting me know. Really appreciate it.
How about if someone on the CRM already has some fields pre-filled such as their Twitter and Linkedin. And when I send out a survey to ALL my contacts to update their details and they fill out Twitter and Linkedin again - it should over-ride the existing fields on the CRM but its creating a new field. Any idea why?
Databaser
  • Aug 23, 2021 7:44 PM UTC
A filled in form always creates a new record. You could use 2 tables, one for the form and one with your list, and then use an automation to update your list with the received input.
It is possible to create a form in one table and then use the “share link” to make a formula in the other table to prefill it. That way, you get the info from one table, but the input in the other one.
