Is there a better way to collect responses from 10-20 sources using the same table?
  • Jun 2, 2021 5:49 PM UTC
  • 25 views
Hi there,
I have created a table I would like to send to 10 to 20 different people. There is one column that has a checkmark option - this is the only option I would like them to edit (check or leave empty). There are more than 200 rows so it’ll be difficult to simply send out a google forms and concatenate inputs into a table.
I was wondering if anyone would like to suggest a clean way to collect this data without having to create 10-20 different tables to send to each person?
Thank you very much for your time!
Warm regards,
Michelle
  • Jun 2, 2021 7:23 PM UTC
I cannot quite picture what you are describing, but you might want to be aware of some of Airtable’s limitations that may make it hard to do what you want.
  • Only Airtable collaborators can directly edit data in a table. If you use Airtable’s method of sharing a table, the table is view only.
  • An Airtable form can collect data from anyone who fills out the web form. However, the result always creates a new record in a single table–one new row with a single value for each column.
Apologies if I’ve misunderstood your use case.
  • Jun 2, 2021 10:36 PM UTC
Thanks for your help Kuovonne!
