merge problem - field not available
  • Nov 16, 2023 4:18 PM UTC
  • 76 views
I'm trying to merge a CSV but the field that I need to map to is not available to select. I can't select the field I need as the merge field. It is not one of the options in the "choose a field" drop down.
Best answer by Databaser
An autonumber field is automatically generated and can't be edited. That's why you can't merge existing data with it.
Databaser
Forum|alt.badge.img+25
  • Nov 16, 2023 4:21 PM UTC
Hi @kharpbrown
What field type is that not available field? And the one that you're trying to merge?
  • Nov 16, 2023 4:30 PM UTC
The field that is not available is a unique number. I'm trying to merge geotagging data.
Databaser
  • Nov 16, 2023 4:33 PM UTC
