Multi Project Gantt View not Showing Critical Path
  • Nov 9, 2022 9:43 PM UTC
  • 48 views
I’m using a template for tracking multiple projects across different teams and workstreams. In my Gantt view, I cannot get a critical path to show to save my life. I understand that the path will only show related tasks that dont overlap, but I have some pretty straightforward waterfall dependencies and still no path. Here’s a screenshot:
I know the show critical path option is on. Not sure if this is because of multiple projects or the view being by quarter. Thanks for your help.
  • Nov 11, 2022 2:07 PM UTC
So update, if I filter by a single project, the critical path will appear. If I add more projects, the additional ones don’t have the critical path highlighted.
So it appears that based on how I have projects organized, gantt won’t highlight critical path - is that expected behavior?
