One screen entry for product & catalog client order? Is is possible?
  • March 16, 2018
  • 32 views
Hi - Im thinking of using the product & catalog orders template (modified) I can get it to do everything I need -
BUT
it seems to enter in a new client order… I have to create the order in the cient order table then enter the line items in the order line items table…
this is NOT ideal
is there any way to configure it so I can enter order details in just one table? or all in one place? Im talking client, date, and the line items??
Then if course I would want that data to populate all the other tables from there.
