Private View/Projects for specific users in Project Tracker
In the Project Tracker base, is there a way to have certain projects viewable for only certain viewers? I have a number of collaborators on read only permissions. Some that need to see only certain views, and some that need to see the entire project table. There are high level projects that only HR and Execs should be seeing though, and I’m having trouble finding a solution outside of making a separate base.
Thanks in advance,
JC.
