Pro Plan Sharing editor mode with Plus plan users
  • Jan 6, 2023 1:48 PM UTC
  • 87 views
I understand that if I share in editor mode a base with someone that has a free plan, this will add 1 billable collaborator to my pro plan. But if I share in editor mode with someone that has a plus plan (10$/month), is that has the same effect on my pro plan and add 1 billable collaborator?
Thanks
Yeap, you'll end up with another billable collaborator on your Pro plan I believe
  • Jan 7, 2023 10:54 AM UTC
Hello Adam, thanks for your answer.
But, it looks a bit like a scam.
Sylvain
