Problem: Scrolling Desktop Airtable in Safari on iPad Pro not functional
  • April 26, 2020
  • 84 views
On iPad Pro running Safari with Airtable Desktop, one cannot scroll the screen to see additional records or additional fields beyond the initial screen.
  • April 26, 2020
Does it work properly in mobile Chrome? I don’t think that Airtable Desktop was designed to support mobile browsers, but maybe it will work in Chrome. You will probably want to download the Airtable app for iPad instead.
  • April 30, 2020
Thanks Scott. Yeah, I’m kind of stuck between the app a Safari. The app doesn’t allow me to select multiple rows. On iPad Pro, Safari is now a desktop class browser—so it loads the desktop version, although it doesn’t allow scrolling as stated before. I’ll try out Chrome, reluctantly :slightly_smiling_face:
  • April 30, 2020
Oh, I don’t know if it will work on mobile Chrome for iOS either — I was just curious if it does. I just tried it on my mobile Chrome for iOS, and it won’t even let me log into Airtable. I’m pretty sure that for mobile usage, you’ll need to use the Airtable app.
