Problem with using Airtable Lookup fields in Integromat
  • Mar 17, 2021 5:18 AM UTC
  • 15 views
Ruchika_Abbi1
There seems to be a problem in using Lookup fields in Module settings.
I had a dev base which I used in Integromat and for that the lookup field shows up as an array and I get to select an item of the array. (See Screenshot)
However, I copied the dev base for production and now the same lookup field shows up differently. This causes problems in my Integromat scenario.
Stuck on this critical issue in Live system! Any suggestions appreciated!
