problème sur le type de champ "Nombre"
  • Apr 17, 2025 1:09 PM UTC
  • 7 replies
  • 163 views
Bonjour,
j'ai crée une table mais le champ type "Nombre" est absent de la liste des champs disponibles.. Avez-vous une explication?
Hm, as a data point, I just created a new base and table and it shows up for me
  • Apr 17, 2025 2:00 PM UTC
Thank you for your answer. I tried again. But the “Number” field is still missing.
  • Apr 17, 2025 2:03 PM UTC
Depending on where your “number” field is located, could it be that in French it’ called “Numero”?
Hm yeah, the ‘#’ icon indicates that ‘Numero’ is the ‘Number’ type field, so that’s the one you’re looking for
That’s an interesting bug you’ve found!
Hey ​@BKR!
If you are still struggling you might want to reach out to Customer Support by following theses steps.
Hoper this helps!
  • Apr 22, 2025 6:42 AM UTC
Thank you evrebody for your support end answers. Everything is ok now! :)
Glad to hear that!
