Setting up Work and Date Columns similar to MS Project
  • January 25, 2020
  • 20 views
Hello Community,
Pretty fresh user here and my background is with MS Project. I’m looking for suggestions on how best to create a “Work” column similar to what you get out of the box with MS Project. What I’ve done thus far is just create a Number column. The problem with that is it isn’t linked to a “Level of Effort” and/or “Duration” column, which means it can’t inform/auto schedule dates for me. For what it’s worth, I do have blockers turned on with everything linked to a predecessor.
Which leads me to my second problem…how can I auto schedule my dates without having to set every task manually?
To simplify, I’m looking for feature parity with MS Project where I can simply add in my Work and then automagically it provides the duration and schedule for me.
