Sort in Alphabetical Order and Using Multiple Field Types on the Same Column
  • Dec 15, 2020 11:51 AM UTC
  • 22 views
Hi Airtable Community,
I am working on a table and I would like for the first column to be sorted in alphabetical order (A --> Z), but when I do this the whole column erases. However, when I do (Z --> A) it does work. Could you please help me out but telling me how to sort the column (A --> Z)?
Additionally, Is there any way I can have two different field types applied to the same column? For example, if I want to have both long text and multi-select on the same column and be able to pick which field type I want to use for each cell of that specific column.
I would highly appreciate your help and I am looking forward to hearing back from you soon!
Thank you,
Yael
  • Dec 15, 2020 3:44 PM UTC
Your entire column didn’t erase… it’s just showing you the empty values first, which appear before the alphabet starts.
Each column can only be one field type.
