Typeform Connnect does not work
  • Nov 23, 2023 9:02 AM UTC
  • 69 views
Since the new Personal Tokens (No API Keys) i cannot connect my airtable to typeform. Does someone has a solution for this?
The extension also does not work for my case, as i have an Opinion Scale, which i cannot map.
Thanks for your help!
  • Nov 23, 2023 11:00 AM UTC
Typeform doesn’t offer full support for Airtable, so you would typically need to use Make’s TypeForm integrations and Make’s Airtable integrations to automatically move your form submissions from TypeForm into Airtable.
Similarly, JotForm doesn’t offer full support for Airtable either, so you would typically use Make’s JotForm integrations to get JotForm form submissions into Airtable.
If you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread. For example, here is one of the ways that you could instantly trigger a Make automation from Airtable.
However, your much much better option for Airtable forms is to use Fillout’s advanced forms for Airtable because it communicates directly with Airtable and can easily do everything that you requested.
Fillout is 100% free, and it offers hundreds of features that Airtable’s native forms don’t offer, including the ability to update Airtable records using a form, create custom PDF files from a form submission, accept payments on forms, pre-fetch dynamic data from an Airtable record, customize the style and branding of your form, customize a theme for your form, display Airtable lookup fields on forms, create new linked records on a form, add a login page to your form, perform math or other live calculations on your forms, collect signatures on a form, create multi-page forms with conditional paths, connect a single form to dozens of external apps simultaneously, add CAPTCHAs to your form, and much more.
