Upgrade to Pro plan and saving your own credits
  • Sep 11, 2021 12:17 PM UTC
  • 91 views
Hi everyone !
I have a personnal plan plus and 1988 dollars credits on it.
I want to upgrade to the Pro plan (20 dollars, paid yearly).
The only thing is that i’m afraid to lose my beautiful credits if i upgrade …
So i want you to ask if the credits are saved when you upgrade your plan :thinking:
Thank you
Best answer by kuovonne
The Pro plan is $20/user/month when paid yearly. Thus, it would cost $240 if you upgrade to a yearly plan. If the credits are already in the workspace, they will be spent on the upgrade. If the credits are tied to your account but not yet assigned to a workspace, you can upgrade without using the credits. However, why wouldn’t you spend the credits on the upgrade? You can’t use the credits for anything else but Airtable.
  • Sep 11, 2021 1:44 PM UTC
Tanks for the answer !
I did it, perfect !
Dominik_Bosnjak
Typical billionaire behavior, they just want to flaunt their wealth smh :grinning_face_with_sweat:
