When syncing from Airtable to Shopify some images drop to an article below and thus images end up with the wrong products
  • Nov 22, 2021 3:53 PM UTC
  • 7 replies
  • 105 views
I am new to Airtable.
We set up an images table. When I synced products from Airtable to our Shopify webshop some images ended up one line lower in the table, and thus images end up with the wrong products.
When I “repaired” the images in the Airtable images table, and synced A>S nevertheless images skipped out of their row to another product and deleted images were still resident in the products table.
How should I properly sync products + their images A>S ?
  • Nov 22, 2021 3:55 PM UTC
How are you syncing your products to Shopify? You would likely want to reach out to the people who created your syncing tool to ask them about that.
  • Nov 22, 2021 4:01 PM UTC
After initial failure we asked Airtable support to check the sync settings.
  • Nov 22, 2021 4:02 PM UTC
We sync using the standard Shopify Airtable tool.
  • Nov 22, 2021 4:04 PM UTC
There is no standard Shopify Airtable tool. Airtable does not provide syncing between Airtable and Shopify. Any syncing between Airtable and Shopify is provided by third-party developers, or is handcrafted for you by using an automation tool like Integromat.
  • Nov 22, 2021 4:10 PM UTC
OK!
Would that be Basegenius?
  • Nov 22, 2021 4:14 PM UTC
OK!
If that’s who sold you your Airtable-Shopify integration, then yes.
Théau12
Forum|alt.badge.img+8
  • Oct 13, 2025 10:49 AM UTC
Hi ​@Marc_Schreuder
You can super easily sync your Products images between Airtable and Shopify using SyncBase app.
=> You will get one record per product, with a field named “Images” (Attachment type) in which you can add or delete images.
Synchronization is instant and support always there for help if needed :)
