Workaround for lack of pre-filled default text using input.textAsync?
  • Aug 23, 2022 3:57 PM UTC
  • 40 views
Samir_Ghosh
Forum|alt.badge.img+16
Unfortunately input.textAsync does not allow a default value. Anyone have a workaround for this? E.g., You can code a default value if user enters nothing, BUT…there’s no way to enter nothing (i.e., requires user to enter a value before proceeding).
  • Aug 23, 2022 4:12 PM UTC
I have two main ways of dealing with this.
  • I start by using a button field with one button per common value, and a final button that lets the user enter a custom value. I only show input.textAsync() if the user selects the button to enter a custom value.
  • I preface the input call by instructing the user to type a single space to indicate “no value”.
