Create Record Issue
  • August 8, 2023
  • 130 views
Good day.
There's an issue across the board when it comes to creating new records. It used to be that a person would fill the details and then click on the "x", which would create a record. This no longer works.
Now it shows a 'create' button when the Interface is in the Edit Mode but doesn't appear when published?
This is a big problem since no-one can create records via the Interface Designer!
Best answer by Ricardo_da_Cost
This is messed up... The Permissions must be toggled off and on, for the button to appear. You know how MANY interfaces I have to update for clients and we - whereby I mean Airtable and I - look like idiots.
  • August 8, 2023
I ran into the same problem today. messed up our workflow @@
DataGuru
Forum|alt.badge.img+9
  • August 8, 2023
Thanks for the workaround.  It will take some work, but I can’t wait for Airtable to respond.
Their Change Management system is truly dysfunctional.  First they dropped the Interface Home page.  Now this!  What will it be next month?
