Looking for a developer for a project-based work: inbox management automation
  • Feb 2, 2025 12:40 PM UTC
  • 7 replies
  • 170 views
I need to automate handling cold email responses - connect Smartlead and Calendly with Airtable using APIs, webhooks and probably Make.com
I will provide a technical specification describing all the methods and how to use them, as well as what the Airtable interface should look like.
Pello
Forum|alt.badge.img+12
  • Feb 2, 2025 12:42 PM UTC
Hi Oleg, I can help with this technical setup. I have plenty of experience with the Airtable API (Python coding) and Make.com integrations. Feel free to plan an intro call here: https://calendly.com/pello-mugicagonzalez
Cheers,
Pello
  • Feb 2, 2025 3:09 PM UTC
@Oleg_Bakatin
If you’d like to hire an expert Airtable & Make consultant to help you with anything Airtable-related and Make-related, please feel free to contact me through my website: Airtable consultant — ScottWorld
Hi Oleg, I'd be happy to help with this!  I've set up systems to feed Calendly data into Airtable before and have a fair amount of experience with Make too!
I'm pretty active on the forums so you can get a grasp of how I work from my activity here as well as some reviews, and I've got a bunch of example projects that you can find here
If you think I could help, here's a link to schedule a free half hour call to see if we're a good fit
Best of luck either way!
Anna_Radnor
  • Feb 3, 2025 6:36 AM UTC
Hello @Oleg_Bakatin
I would be glad to assist you.
To discuss further in detail kindly reach me at annaradnor70@gmail.com.
Thanks
Anna
Hi, @Oleg_Bakatin:
I've worked on several similar projects with multiple integrations and would be happy to discuss your project. You an schedule a free 30-minute call for us to chat here. It's a great opportunity for you to get to know me, a feel for how I work and then discuss the details of your project.
Best of luck,
Leslie Burke
www.burkeconsulting.io
karimzynera
  • Feb 3, 2025 4:50 PM UTC
Hi Oleg,
I'd be happy to help with this! At Zynera, we specialize in no-code automation, and I've worked extensively with Make, APIs, and webhooks to integrate tools like Smartlead, Calendly, and Airtable.
If you'd like to discuss further, feel free to schedule a free discovery call here: https://cal.com/zynera/discovery.
Looking forward to connecting!
Best,
Karim @ Zynera
Dimitris_Goudis
Forum|alt.badge.img+20
Hey @Oleg_Bakatin,
Would you like to get to know how to build your system?
I am conducting co-building sessions, during which we work live on your system. While I am building your Airtable base interfaces and creating scenarios, I am explaining the steps and how the tools work so you can better understand them.
Working live together helps us build your entire system in a couple of hours instead of weeks. You will know exactly how the features were built, so you can update them later.
Happy to schedule a 30-minute conversation with no commitment to discuss your project requirements and share my suggestions on this. Here is the link to my calendar: https://cal.com/dimitrisgoudis/meet-dimitris
Thanks
Dimitris Goudis | 3Nuggets
